Subradiance in a large cloud of cold atoms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2015
Since Dicke's seminal paper on coherence in spontaneous radiation by atomic ensembles, superradiance has been extensively studied. Subradiance, on the contrary, has remained elusive, mainly because subradiant states are weakly coupled to the environment and are very sensitive to nonradiative decoherence processes. Here we report the direct observation of subradiance in an extended and dilute cold-atom sample containing a large number of particles. We use a far detuned laser to avoid multiple scattering and observe the temporal decay after a sudden switch-off of the laser beam. After the fast decay of most of the fluorescence, we detect a very slow decay, with time constants as long as 100 times the natural lifetime of the excited state of individual atoms. This subradiant time constant scales linearly with the cooperativity parameter, corresponding to the on-resonance optical thickness of the sample, and is independent of the laser detuning, as expected from a coupled-dipole model.
Subradiance_arXiv_v2.pdf (607.26 Ko) Télécharger le fichier
hal-01189090 , version 1 (01-09-2015)
hal-01189090 , version 2 (09-09-2015)
hal-01189090 , version 3 (14-01-2016)
hal-01189090 , version 4 (23-03-2016)
William Guerin, Michelle O. Araujo, Robin Kaiser. Subradiance in a large cloud of cold atoms. 2015. ⟨hal-01189090v2⟩
206 Consultations
274 Téléchargements
