New interface
Poster communications
Modeling Surface Currents in the Eastern Levantine Mediterranean
Abstract : We consider the problem of reconstructing the meso-scale features of the currents in the Eastern Levantine Mediterranean from combining in-situ and satellite altimetry data. Mathematically, this is an inverse problem where the objective is to invert Lagrangian trajectories, which are positions of drifters launched at sea, in order to improve the coarse Eulerian velocity, provided by the altimetric satellite measurements. We shall use a variational assimilation approach, whereby the eulerian velocity correction is obtained by minimizing the distance between the simulated position from a velocity background and actual observations. One important property of our approach is that it is model free, so that it is inexpensive and can be easily cast into real-time oceanic operational products. Our method is first validated with twin experiments, where we conduct sensitivity analysis to parameters such as number of drifters, assimilation time window and spatial filter length. The approach is next validated with past and present data from the Levantine Mediterranean by correcting velocity fields derived from altimetry by assimilating drifters' data. The drifters' data used here were collected in the context of the MedSVP program and more recently by the National Lebanese Marine Center (CNSM) in September 2013. The CNSM with its boat CANA has developed an important activity of data collection along the Lebanese coast so far and this activity will permit it to extend its collaborations further by integrating the modeling and data assimilation methods for reconstructing the surface currents.
Document type :
Complete list of metadata
https://hal.inria.fr/hal-01191755
Contributor : Nathalie Gaudechoux Connect in order to contact the contributor
Submitted on : Monday, October 17, 2016 - 9:57:26 AM
Last modification on : Tuesday, October 25, 2022 - 4:19:39 PM
File
Brajard-EGU-2015.pdf
Identifiers
Citation
Leila Issa, Julien Brajard, Milad Fakhri, Laurent Mortier, Pierre-Marie Poulain. Modeling Surface Currents in the Eastern Levantine Mediterranean. EGU General Assembly Conference, Apr 2015, Vienna, Austria. 17, pp.8888. ⟨hal-01191755⟩
Share
Metrics
Record views
187
Files downloads
61
