Considerations on Grattan Guinness Cycle, of 391Yrs
GGC of 391 years was applied to dates of intense eclipse cycles. A normal year will have 2 solar (S) and 2 lunar (L) eclipses for a total of 4 eclipses. This review found 8 eclipses can happen in a little as 370 days, or possibly less. Consider the year 26 to 27 AD. Here are found 3 Solar and 5 lunar eclipses in 370 days from August 1/26 AD unto August 6/27 AD. It was further found that the 6000 years of civilized history may be described in terms of GGC and the intense eclipse cycles from 1865 unto 2027. It is also determined that the Fourier series may be used to correct the mean new moon date of Vernal Equinox. The GGC is shown to predict alignment dates for Vernal Equinox and new moon conjunctions. days pseudo-epact day of January Conjunction: (1+MOD((365.242454*(-4006-Yr)),29.5306)) &if>=30, then subtract 30, by excel. Date of new moon by excel, use above with constant of 0.5 instead of 1. This method known as Astronomical Easter, verified for y2k to 2024, in particular for 2019. In 2019 astronomical method gives March Easter, rather than April. The 1997 Aleppo WCC did not adapt the astro easter method.
Mots clés
luis vega
2000 ad
grattan guinness eclipse cycle
391 years
26 a.d.
date for saint john the baptist start
lunar cycles of same gregorian day
lunar cycles of spring equinox
fourier series correction of lunation number
fourier series correction of mean new moon age
spring new moon dates
4000 bc
dating 15th year of tiberius caesar by eclipse patterns
spring equinox eclipse series date
daniel cycle
1040 2300 1260 years
vernal equinox eclipse cycles
date of spring equinox eclipse
simple epact excel formula
simple excel epact formula
Sciences de l'ingénieur [physics]
