Rabbit genome analysis reveals a polygenic basis for phenotypic change during domestication - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Science Année : 2014
Miguel Carneiro
  • Fonction : Auteur
Carl-Johan Rubin
  • Fonction : Auteur
Alvaro Martinez Barrio
  • Fonction : Auteur
Gerli Pielberg
  • Fonction : Auteur
Nima Rafati
  • Fonction : Auteur
Shady Younis
  • Fonction : Auteur
Sandra Afonso
  • Fonction : Auteur
Joel M. Alves
  • Fonction : Auteur
  • PersonId : 969750
Samuel Boucher
  • Fonction : Auteur
  • PersonId : 948065
Rita Campos
  • Fonction : Auteur
Luca Fontanesi
  • Fonction : Auteur
Rose G Mage
  • Fonction : Auteur
Guillaume Queney
  • Fonction : Auteur
Anqi Xiong
  • Fonction : Auteur
Sarah Young
Karin Forsberg-Nilsson
  • Fonction : Auteur
Nuno Ferrand
  • Fonction : Auteur
The genetic changes underlying the initial steps of animal domestication are still poorly understood. We generated a high-quality reference genome for the rabbit and compared it to resequencing data from populations of wild and domestic rabbits. We identified more than 100 selective sweeps specific to domestic rabbits but only a relatively small number of fixed (or nearly fixed) single-nucleotide polymorphisms (SNPs) for derived alleles. SNPs with marked allele frequency differences between wild and domestic rabbits were enriched for conserved noncoding sites. Enrichment analyses suggest that genes affecting brain and neuronal development have often been targeted during domestication. We propose that because of a truly complex genetic background, tame behavior in rabbits and other domestic animals evolved by shifts in allele frequencies at many loci, rather than by critical changes at only a few domestication loci.
emss-72093.pdf (1.64 Mo) Télécharger le fichier
hal-01193854 , version 1 (19-04-2024)
Miguel Carneiro, Carl-Johan Rubin, Federica Di Palma, Franck W. Albert, Jessica Alföldi, et al.. Rabbit genome analysis reveals a polygenic basis for phenotypic change during domestication. Science, 2014, 345 (6200), pp.1074-1079. ⟨10.1126/science.1253714⟩. ⟨hal-01193854⟩
191 Consultations
0 Téléchargements
