Guaranteed and robust a posteriori bounds for Laplace eigenvalues and eigenvectors: conforming approximations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2016
This paper derives a posteriori error estimates for conforming numerical approximations of the Laplace eigenvalue problem with a homogeneous Dirichlet boundary condition. In particular, upper and lower bounds for the first eigenvalue are given. These bounds are guaranteed, fully computable, and converge with the optimal speed to the exact eigenvalue. They are valid without any restriction on the computational mesh or on the approximate eigenvector; we only need to assume that the approximate eigenvalue is smaller than a computable lower bound on the second smallest eigenvalue, which can be checked in practice. Guaranteed, fully computable, optimally convergent, and polynomial-degree robust bounds on the energy error in the approximation of the first eigenvector are derived as well, under the same hypotheses. Remarkably, there appears no unknown (solution-, regularity-, or polynomial-degree-dependent) constant in our theory, and no convexity/regularity assumption on the computational domain/exact eigenvector(s) is needed. Two improvements of the multiplicative constant appearing in our estimates are presented. First, it is reduced by a fixed factor under an explicit, a posteriori calculable condition on the mesh and on the approximate eigenvector--eigenvalue pair. Second, when an elliptic regularity assumption is satisfied with known constants, it can be brought to the optimal value one. The application of our framework to conforming finite element approximations of arbitrary polynomial degree is provided, along with a numerical illustration on a set of test problems.
a_post_Lapl_conf.pdf (1.34 Mo) Télécharger le fichier
hal-01194364 , version 1 (06-09-2015)
hal-01194364 , version 2 (27-06-2016)
hal-01194364 , version 3 (15-12-2016)
  • HAL Id : hal-01194364 , version 2
Eric Cancès, Geneviève Dusson, Yvon Maday, Benjamin Stamm, Martin Vohralík. Guaranteed and robust a posteriori bounds for Laplace eigenvalues and eigenvectors: conforming approximations. 2016. ⟨hal-01194364v2⟩
881 Consultations
657 Téléchargements
