Games with Communication: from Belief to Preference Change - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this work we consider simple extensive-form games with two players, Player A and Player B, where Player B can make announcements about his strategy. Player A has then to revise her preferences about her strategies, so as to better respond to the strategy she believes Player B will play. We propose a generic framework that combines methods and techniques from belief revision theory and social choice theory to address this problem. Additionally, we design a logic that Player A can use to reason and decide how to play in such games.
PRIMA2015.pdf (272.13 Ko) Télécharger le fichier
hal-01194398 , version 1 (06-09-2015)
  • HAL Id : hal-01194398 , version 1
Guillaume Aucher, Bastien Maubert, Sophie Pinchinat, François Schwarzentruber. Games with Communication: from Belief to Preference Change. Principles and Practice of Multi-Agent Systems (PRIMA 2015), Oct 2015, Bertinoro, Italy. ⟨hal-01194398⟩
362 Consultations
218 Téléchargements
