A variant of the Recoil Growth algorithm to generate multi-polymer systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Discrete Mathematics and Theoretical Computer Science Année : 2008
Florian Simatos
  • Fonction : Auteur
  • PersonId : 841874
The Recoil Growth algorithm, proposed in 1999 by Consta $\textit{et al.}$, is one of the most efficient algorithm available in the literature to sample from a multi-polymer system. Such problems are closely related to the generation of self-avoiding paths. In this paper, we study a variant of the original Recoil Growth algorithm, where we constrain the generation of a new polymer to take place on a specific class of graphs. This makes it possible to make a fine trade-off between computational cost and success rate. We moreover give a simple proof for a lower bound on the irreducibility of this new algorithm, which applies to the original algorithm as well.
dmAI0118.pdf (224.26 Ko) Télécharger le fichier
hal-01194686 , version 1 (07-09-2015)
Florian Simatos. A variant of the Recoil Growth algorithm to generate multi-polymer systems. Fifth Colloquium on Mathematics and Computer Science, 2008, Kiel, Germany. pp.283-294, ⟨10.46298/dmtcs.3571⟩. ⟨hal-01194686⟩
108 Consultations
639 Téléchargements
