Dirichlet-to-Neumann operator for diffraction problems in stratified anisotropic acoustic waveguides - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2015
The purpose of this note is to construct a Dirichlet-to-Neumann operator for the diffraction problem in stratified anisotropic acoustic waveguides. The key idea consists in using an adapted change of coordinates that enables to recover the completeness and the orthogonality of the modes on " deformed " cross-sections of the waveguide. To cite this article:
Dirichlet to Neumann operator for diffraction problems in stratified anisotropic acoustic waveguides.pdf (736.89 Ko) Télécharger le fichier
hal-01195869 , version 1 (08-09-2015)
hal-01195869 , version 2 (05-12-2015)
  • HAL Id : hal-01195869 , version 1
Antoine Tonnoir. Dirichlet-to-Neumann operator for diffraction problems in stratified anisotropic acoustic waveguides. 2015. ⟨hal-01195869v1⟩
233 Consultations
385 Téléchargements
