Approximate Counting via the Poisson-Laplace-Mellin Method - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Discrete Mathematics and Theoretical Computer Science Année : 2012
Approximate counting is an algorithm that provides a count of a huge number of objects within an error tolerance. The first detailed analysis of this algorithm was given by Flajolet. In this paper, we propose a new analysis via the Poisson-Laplace-Mellin approach, a method devised for analyzing shape parameters of digital search trees in a recent paper of Hwang et al. Our approach yields a different and more compact expression for the periodic function from the asymptotic expansion of the variance. We show directly that our expression coincides with the one obtained by Flajolet. Moreover, we apply our method to variations of approximate counting, too.
dmAQ0102.pdf (332.57 Ko) Télécharger le fichier
hal-01197238 , version 1 (11-09-2015)
Michael Fuchs, Chung-Kuei Lee, Helmut Prodinger. Approximate Counting via the Poisson-Laplace-Mellin Method. 23rd International Meeting on Probabilistic, Combinatorial, and Asymptotic Methods in the Analysis of Algorithms (AofA'12), 2012, Montreal, Canada. pp.13-28, ⟨10.46298/dmtcs.2980⟩. ⟨hal-01197238⟩
Collections
TDS-MACS
111 Consultations
608 Téléchargements
