On Computing the Hyperbolicity of Real-World Graphs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The (Gromov) hyperbolicity is a topological property of a graph, which has been recently applied in several different contexts, such as the design of routing schemes, network security, computational biology, the analysis of graph algorithms, and the classification of complex networks. Computing the hyperbolicity of a graph can be very time consuming: indeed, the best available algorithm has running-time O(n^{3.69}), which is clearly prohibitive for big graphs. In this paper, we provide a new and more efficient algorithm: although its worst-case complexity is O(n^4), in practice it is much faster, allowing, for the first time, the computation of the hyperbolicity of graphs with up to 200,000 nodes. We experimentally show that our new algorithm drastically outperforms the best previously available algorithms, by analyzing a big dataset of real-world networks. Finally, we apply the new algorithm to compute the hyperbolicity of random graphs generated with the Erdös-Renyi model, the Chung-Lu model, and the Configuration Model.
Mots clés
BCCM15.pdf (590.35 Ko) Télécharger le fichier
hal-01199860 , version 1 (16-09-2015)
Michele Borassi, David Coudert, Pierluigi Crescenzi, Andrea Marino. On Computing the Hyperbolicity of Real-World Graphs. 23rd Annual European Symposium on Algorithms (ESA), Sep 2015, Patras, Greece. pp.215-226, ⟨10.1007/978-3-662-48350-3_19⟩. ⟨hal-01199860⟩
275 Consultations
562 Téléchargements
