Vector control applied to a Langevin transducer - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, the control of the vibration amplitude of a Langevin transducer is obtained simultaneously with the tracking of its resonant frequency. Vector control method is applied to achieve this. The result of this study is illustrated with experimental and simulation results.
EPE_Final_paper_ghenna_sofiane.pdf (551.31 Ko) Télécharger le fichier
hal-01201885 , version 1 (18-09-2015)
  • HAL Id : hal-01201885 , version 1
Sofiane Ghenna, Frédéric Giraud, Christophe Giraud-Audine, Michel Amberg, Betty Lemaire-Semail. Vector control applied to a Langevin transducer. Conference on Power Electronics and Applications, Sep 2015, Genève, Switzerland. ⟨hal-01201885⟩
291 Consultations
310 Téléchargements
