Analysis of Timing Constraints in Heterogeneous Middleware Interactions
With the emergence of Future Internet applications that connect web services, sensor-actuator networks and service feeds, scalability and heterogeneity support of interaction paradigms are of critical importance. Heterogeneous interactions can be abstractly represented by client-service, publish-subscribe and tuple space middleware connectors that are interconnected via bridging mechanisms providing interoperability among the services. In this paper, we make use of the eXtensible Service Bus (XSB), proposed in the CHOReOS project as the connector enabling interoperability among heterogeneous choreography participants. XSB models transactions among peers through generic post and get operations that represent peer behavior with varying time/space coupling. Nevertheless, the heterogeneous lease and timeout constraints of these operations severely affect latency and success rates of transactions. By precisely studying the related timing thresholds using timed automata models, we verify conditions for successful transactions with XSB connectors. Furthermore, we statistically analyze through simulations, the effect of varying lease and timeout periods to ensure higher probabilities of successful transactions. Simulation experiments are compared with experiments run on the XSB implementation testbed to evaluate the accuracy of results. This work can provide application developers with precise design time information when setting these timing thresholds in order to ensure accurate runtime behavior.
