Energy-efficient User-oriented Cloud Elasticity for Data-driven Applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Nowadays enormous amounts of energy are consumed by Cloud infrastructures and this trend is still growing. An existing solution to lower this consumption is to turn off as many servers as possible, but these solutions do not involve the user as a main lever to save energy. We propose a system that proposes to the user to run her application with degraded performance. A user choosing an energy-efficient run promotes a better consolidation of the Virtual Machines in the Cloud and thus may help turning off more servers. We experimented our system on Grid'5000 and we used the Montage workflow as a benchmark. Experimentation results show promising outcomes. In energy-efficiency mode, the energy consumed can be significantly reduced to the cost of a low increase of the execution time.
PID3946439.pdf (477.19 Ko) Télécharger le fichier
hal-01205915 , version 1 (04-12-2015)
  • HAL Id : hal-01205915 , version 1
David Guyon, Anne-Cécile Orgerie, Christine Morin. Energy-efficient User-oriented Cloud Elasticity for Data-driven Applications. IEEE International Conference on Green Computing and Communications (GreenCom), Dec 2015, Sydney, Australia. ⟨hal-01205915⟩
390 Consultations
280 Téléchargements
