Non-parametric level set estimation for spatial data - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Advances and Applications in Statistics Année : 2015
A non-parametric level set estimator of the density of a stationary d-dimensional spatial process is proposed. The estimator is deduced from a non-parametric kernel density estimator. Berry-Esseen bounds are established and used to give consistency results of the kernel level set estimation, derived from that of the kernel density estimate under some mild conditions.
Fichier non déposé
hal-01206787 , version 1 (29-09-2015)
Sophie Dabo-Niang, Guy-Martial Nkiet, Stéphane Bouka. Non-parametric level set estimation for spatial data. Advances and Applications in Statistics, 2015, 46 (2), pp.119 - 158. ⟨10.17654/ADASAug2015_119_158⟩. ⟨hal-01206787⟩
191 Consultations
0 Téléchargements
