Cell morphing: from array programs to array-free Horn clauses
Automatically verifying safety properties of programs is hard.
Many approaches exist for verifying programs operating on Boolean and integer values (e.g. abstract interpretation, counterexample-guided abstraction refinement using interpolants), but transposing them to array properties has been fraught with difficulties.
Our work addresses that issue with a powerful and flexible abstraction
that morphes concrete array cells into a finite set of abstract
ones. This abstraction is parametric both in precision and in the
back-end analysis used.
From our programs with arrays, we generate nonlinear Horn clauses over
scalar variables only, in a common format with clear and unambiguous
logical semantics, for which there exist several solvers. We thus
avoid the use of solvers operating over arrays, which are still very
immature.
Experiments with our prototype VAPHOR show that this approach can prove
automatically and without user annotations
the functional correctness of several classical examples, including \emph{selection sort}, \emph{bubble sort}, \emph{insertion sort}, as well as examples from literature on array analysis.
