Kernel-type estimators of divergence measures and its strong uniform consistency - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2015
In this paper, we develop a kernel-type estimators of divergence measures for continuous distributions. We use the method based on empirical process techniques for consistence kernel-type function estimators to show a general result for the strong uniform consistency of our proposal divergence estimators
elsarticle-template.pdf (154.19 Ko) Télécharger le fichier
hal-01207481 , version 1 (01-10-2015)
  • HAL Id : hal-01207481 , version 1
Hamza Dhaker, Papa Ngom, El Hadji Deme, Pierre Mendy. Kernel-type estimators of divergence measures and its strong uniform consistency. 2015. ⟨hal-01207481⟩
100 Consultations
137 Téléchargements
