Range and critical generations of a random walk on Galton-Watson trees - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Annales de l'Institut Henri Poincaré (B) Probabilités et Statistiques Année : 2018
In this paper we consider a random walk in random environment on a tree and focus on the boundary case for the underlying branching potential. We study the range $R_n$ of this walk up to time $n$ and obtain its correct asymptotic in probability which is of order $n/\log n$. Thisresult is a consequence of the asymptotical behavior of the number of visited sites at generations of order $(\log n)^2$,which turn out to be the most visited generations. Our proof which involves a quenched analysisgives a description of the typical environments responsible for the behavior of $R_n$.
RWRE-modified-X3105.pdf (413.65 Ko) Télécharger le fichier
hal-01211586 , version 1 (05-10-2015)
hal-01211586 , version 2 (21-06-2016)
Pierre Andreoletti, Xinxin Chen. Range and critical generations of a random walk on Galton-Watson trees. Annales de l'Institut Henri Poincaré (B) Probabilités et Statistiques, 2018, 54 (1). ⟨hal-01211586v2⟩
273 Consultations
150 Téléchargements
