Decentralized Innovation Marking for Neural Controllers in Embodied Evolution - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We propose a novel innovation marking method for Neuro-Evolution of Augmenting Topologies in Embodied Evolutionary Robotics. This method does not rely on a centralized clock, which makes it well suited for the decentralized nature of EE where no central evolutionary process governs the adaptation of a team of robots exchanging messages locally. This method is inspired from event dating algorithms, based on logical clocks, that are used in distributed systems, where clock synchronization is not possible. We compare our method to odNEAT, an algorithm in which agents use local time clocks as innovation numbers, on two multi-robot learning tasks: navigation and item collection. Our experiments showed that the proposed method performs as well as odNEAT, with the added benefit that it does not rely on synchronization of clocks and is not affected by time drifts.
tweannNoFormat.pdf (719.66 Ko) Télécharger le fichier
hal-01212761 , version 1 (08-10-2015)
Iñaki Fernández Pérez, Amine Boumaza, François Charpillet. Decentralized Innovation Marking for Neural Controllers in Embodied Evolution. GECCO '15, 2015 Annual Conference on Genetic and Evolutionary Computation, Jul 2015, Madrid, Spain. ⟨10.1145/2739480.2754759⟩. ⟨hal-01212761⟩
155 Consultations
183 Téléchargements
