Featherweight OCL: A Proposal for a Machine-Checked Formal Semantics for OCL 2.5
The Unified Modeling Language (UML) is one of the few modeling
languages that is widely used in industry. While UML is mostly known
as diagrammatic modeling language (e.g., visualizing class models), it
is complemented by a textual language, called Object Constraint
Language (OCL). The current version of OCL is based on a four-valued
logic that turns UML into a formal language. Any type comprises the
elements "invalid" and "null" which are propagated as strict and
non-strict, respectively. Unfortunately, the former semi-formal
semantics of this specification language, captured in the "Annex A" of
the OCL standard, leads to different interpretations of corner
cases. We formalize the core of OCL: denotational definitions, a
logical calculus and operational rules that allow for the execution of
OCL expressions by a mixture of term rewriting and code
compilation. Our formalization reveals several inconsistencies and
contradictions in the current version of the OCL standard. Overall,
this document is intended to provide the basis for a machine-checked
text "Annex A" of the OCL standard targeting at tool implementors.
