ON THE MINIMUM WEIGHT CODEWORDS OF SOME BINARY BCH CODES - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1991
Nicolas Sendrier
We give the true minimum distances of some BCH codes of length 255 and 511, which were not known. We describe the set of the minimum weight codewords of the BCH codes with designed distance 2^{m-2}-1
00695060.pdf (83.2 Ko) Télécharger le fichier
hal-01216856 , version 1 (17-10-2015)
  • HAL Id : hal-01216856 , version 1
Daniel Augot, Pascale Charpin, Nicolas Sendrier. ON THE MINIMUM WEIGHT CODEWORDS OF SOME BINARY BCH CODES. ISIT 2991, Jun 1991, Budapest, Hungary. pp.7-7. ⟨hal-01216856⟩
Collections
INRIA INRIA2
88 Consultations
56 Téléchargements
