The Application Study of Electronic Farming in the Ecology Construction in Chinese Tropical Area
In this paper, which takes Hainan as an example, analyze the
application of Electronic agriculture affairs in the process of building
ecology, and aims at proposing the application strategy of Electronic
agriculture affairs. The paper points out the advantages of applying
electronic agriculture affairs in building ecology and the ways to carry
it out. It takes the application of electronic agriculture affairs of
Hainan as the focal point and analyzes its application mode. Together
with the analysis of the application situation in other areas, it
summarizes the problems in the process of applying electronic
agriculture affairs. At last, it proposes the countermeasures and
solutions in application of electronic agriculture affairs.
