Simulation Study of Winter Wheat Photosynthate Distribution Effect on Controlled Water and Fertilizer Measure
From the morphological characteristics of crop growth, the mechanism
model of photosynthate distribution based on the dynamic ralationship
between root, shoot, leaf and grain is proposed in this paper. And the
method of the determining model parameters with the field experiment
data is proposed. The root-cap growth equilibrium coefficient, the
shoot-leaf growth equilibrium coefficient, the grain-shoot growth
equilibrium coefficient, the water stressed coefficient and the nutrient
stressed coefficient are obtained by the nonlinear program according to
the measured dry matter of the winter wheat root, shoot, leaf and grain
in 2008 in the irrigation experiment station of Tianjin argricultutal
university and the objective function of the minimum absolute error sum
on the simulated and measured dry weight. And they are verified by the
the winter wheat measured data in the irrigation experiment station of
Tianjin argricultutal university in 2009. The results show that the
simulated value and observed data of the dry weight of root, stem, leaf
and grain are consistent. The correlation coefficients
(R2) of the comparison between simulated
and measured value of the root, shoot, leaf and grain dry weight on
every treatments were all over 0.81. It shows that the model on the
simulation of the root, shoot, leaf and grain in this paper is
reasonable. It provides a theoretical basis on reasonable farmland
irrigation and fertilization.
Informatique [cs]
