Research on the Construction and Implementation of Soil Fertility Knowledge Based on Ontology - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Conference Papers Year : 2014
Soil fertility is the comprehensive reflection of related factors and the related factors. Soil fertility evaluation knowledge is stored by relational database as usually, and it is difficult to show the correlation and constraints among attributes .In this paper, Nongan county farmland productivity data is as the research object, Using rough set approach to do attribute reduction, using ontology method to establish the soil fertility level knowledge base, using multi Agent technology to implement the prototype system, and complete the reuse and sharing of knowledge, lay the foundation for semantic level reasoning.
978-3-642-54341-8_14_Chapter.pdf (4 Ko) Télécharger le fichier
Dates and versions
hal-01220822 , version 1 (27-10-2015)
Attribution
Identifiers
Cite
Li Ma, Helong Yu, Guifen Chen, Liying Cao, Yue Wang. Research on the Construction and Implementation of Soil Fertility Knowledge Based on Ontology. 7th International Conference on Computer and Computing Technologies in Agriculture (CCTA), Sep 2013, Beijing, China. pp.138-144, ⟨10.1007/978-3-642-54341-8_14⟩. ⟨hal-01220822⟩
69 View
85 Download
Share
