Research and Application of Variable Rate Fertilizer Applicator System Based on a DC Motor
With the aim to simplify the electrical component structure of the
present variable rate fertilizer applicator system, a kind of variable
rate fertilizer applicator control system was developed. It is based on
low voltage DC motor. The working voltage of this system is not higher
than 12V DC, which can be supplied by the tractor’s storage
battery directly. With the encoder measuring the motor speed, it could
response the running state of the motor in real time. A kind of control
model based on PID algorithm was built. With this model, the influence
of load variation on the motor speed could reduce. As a result, the
control accuracy of this system could be improved. Field experiment has
been conducted using this system. Experiment showed that when the travel
speed was 3.60km/h, the maximum fertilizer rate could be 850 kg /
hm2. When the fertilizer rate was 200 ~
600 kg/ hm2, the mean error of this system
was 1.71% while the maximum error was 2.56%.
Informatique [cs]
