A Smart Multi-parameter Sensor with Online Monitoring for the Aquaculture in China - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Conference Papers Year : 2014
PH, DO,ORP, EC and water-level are important parameters of the aquaculture monitoring. But the high cost of foreign sensors and high-energy consumption of Chinese sensors make it impossible for wide use in China. This paper uses MCU STM8L152 to realize the ultralow power design. With simple hardware structure design, the cost of the multi-parameter sensor can be reduced .The experiment data of the multi-parameter sensor contrasting with the results obtained by Hach multi-parmeter meter, indicates that the sensor is reliable to monitor the water quality with low cost, high efficiency and good precision.
978-3-642-54341-8_46_Chapter.pdf (4 Ko) Télécharger le fichier
Dates and versions
hal-01220855 , version 1 (27-10-2015)
Attribution
Identifiers
Cite
Fa Peng, Jinxing Wang, Shuangxi Liu, Daoliang Li, Dan Xu, et al.. A Smart Multi-parameter Sensor with Online Monitoring for the Aquaculture in China. 7th International Conference on Computer and Computing Technologies in Agriculture (CCTA), Sep 2013, Beijing, China. pp.444-452, ⟨10.1007/978-3-642-54341-8_46⟩. ⟨hal-01220855⟩
124 View
105 Download
Share
