Application of LS-SVM and Variable Selection Methods on Predicting SSC of Nanfeng Mandarin Fruit - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Conference Papers Year : 2014
Tong Sun
  • Function : Author
  • PersonId : 972261
Wenli Xu
  • Function : Author
  • PersonId : 972262
Tian Hu
  • Function : Author
  • PersonId : 972263
Muhua Liu
  • Function : Author
  • PersonId : 972264
The objective of this research was to investigate the performance of LS-SVM combined with several variable selection methods to assess soluble solids content (SSC) of Nanfeng mandarin fruit. Visible/near infrared (Vis/NIR) diffuse reflectance spectra of samples were acquired by a QualitySpec spectrometer in the wavelength range of 350~1800 nm. Four variable selection methods were conducted to select informative variables for SSC, and least squares-support vector machine (LS-SVM) with radial basis function (RBF) kernel was used develop calibration models. The results indicate that four variable selection methods are useful and effective to select informative variables, and the results of LS-SVM with these variable selection methods are comparable to the results of full-spectrum partial least squares (PLS). Genetic algorithm (GA) combined with successive projections algorithm (SPA) is the best variable selection method among these four methods. The correlation coefficients and RMSEs in LS-SVM with GA-SPA model for calibration, validation and prediction sets are 0.935, 0.560%, 0.912, 0.631% and 0.933, 0.594%, respectively.
978-3-642-54344-9_31_Chapter.pdf (4 Ko) Télécharger le fichier
Dates and versions
hal-01220926 , version 1 (27-10-2015)
Attribution
Identifiers
Cite
Tong Sun, Wenli Xu, Tian Hu, Muhua Liu. Application of LS-SVM and Variable Selection Methods on Predicting SSC of Nanfeng Mandarin Fruit. 7th International Conference on Computer and Computing Technologies in Agriculture (CCTA), Sep 2013, Beijing, China. pp.249-262, ⟨10.1007/978-3-642-54344-9_31⟩. ⟨hal-01220926⟩
74 View
116 Download
Share
