Accurate approximate diagnosability of stochastic systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Diagnosis of partially observable stochastic systems prone to faults was introduced in the late nineties. Diagnosability, i.e. the existence of a diagnoser, may be specified in different ways: (1) exact diag-nosability (called A-diagnosability) requires that almost surely a fault is detected and that no fault is erroneously claimed while (2) approximate diagnosability (called ε-diagnosability) allows a small probability of error when claiming a fault and (3) accurate approximate diagnosability (called AA-diagnosability) requires that this error threshold may be chosen arbitrarily small. Here we mainly focus on approximate diagnoses. We first refine the almost sure requirement about finite delay introducing a uniform version and showing that while it does not discriminate between the two versions of exact diagnosability this is no more the case in approximate diagnosis. Then we establish a complete picture for the decid-ability status of the diagnosability problems: (uniform) ε-diagnosability and uniform AA-diagnosability are undecidable while AA-diagnosability is decidable in PTIME, answering a longstanding open question.
AA-main.pdf (442.15 Ko) Télécharger le fichier
hal-01220954 , version 1 (28-10-2015)
hal-01220954 , version 2 (07-12-2015)
Copyright (Tous droits réservés)
  • HAL Id : hal-01220954 , version 2
Nathalie Bertrand, Serge Haddad, Engel Lefaucheux. Accurate approximate diagnosability of stochastic systems. 10th International Conference on Language and Automata Theory and Applications, Mar 2016, Prague, Czech Republic. ⟨hal-01220954v2⟩
793 Consultations
319 Téléchargements
