Design and Implementation of Laiwu Black Information Management System Based on ExtJS
Aimed at the problems of low level of informatization in LaiWu
blackpig process and the old way of using paper for date storage, in
order to speed upthe informatization development of the process, the
LaiWu black pig information management system based on ExtJS is
designed. In this paper, the design and realization of the system, as
well as the open source framework is illustrated in detail, the
ExtJS+SSH(Sturts+Spring+Hibernate)framework exploration model is put
forward,and the separation of page and is realized. The result of system
operation shows that not only the level of informatization in LaWu black
pig process is improved, but also its maintainability and expandability
are developed.
Informatique [cs]
