On Conditions of Oscillations and Multi-Homogeneity - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mathematics of Control, Signals, and Systems Année : 2016
The notion of homogeneity in the bi-limit from [1] is extended to local homogeneity and then to homogeneity in the multi-limit. The converse Lyapunov/Chetaev theorems on (homogeneous) system instability are obtained. The problem of oscillation detection for nonlinear systems is addressed. The sufficient conditions of oscillation existence for systems homogeneous in the multi-limit are formulated. The proposed approach estimates the number of oscillating modes and the regions of their location. Efficiency of the technique is demonstrated on several examples.
oscillations_in_homogeneous_systems.pdf (448.3 Ko) Télécharger le fichier
hal-01223154 , version 1 (02-11-2015)
Denis Efimov, Wilfrid Perruquetti. On Conditions of Oscillations and Multi-Homogeneity. Mathematics of Control, Signals, and Systems, 2016, 28 (3), ⟨10.1007/s00498-015-0157-y⟩. ⟨hal-01223154⟩
139 Consultations
270 Téléchargements
