Computing Periodic Triangulations
The talk presents work on periodic triangulations and meshes, in the Euclidean case as well as the hyperbolic case.
Géométrie algorithmique [cs.CG]
soumis.pdf (649.26 Ko)
Télécharger le fichier
shape-up-hal.pdf (4.93 Mo)
Format : Figure, Image
