On the use of Perfectly Matched Layers at corners for scattering problems with sign-changing coefficients - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Computational Physics Année : 2016
We investigate in a 2D setting the scattering of time-harmonic electromagnetic waves by a plasmonic device, represented as a non dissipative bounded and penetrable obstacle with a negative permittivity. Using the $\texttt{T}$-coercivity approach, we first prove that the problem is well-posed in the classical framework $H^1_{loc}$ if the negative permittivity does not lie in some critical interval whose definition depends on the shape of the device. When the latter has corners, for values inside the critical interval, unusual strong singularities for the electromagnetic field can appear. In that case, well-posedness is obtained by imposing a radiation condition at the corners to select the outgoing black-hole plasmonic wave, that is the one which carries energy towards the corners. A simple and systematic criterion is given to define what is the outgoing solution. Finally, we propose an original numerical method based on the use of Perfectly Matched Layers at the corners. We emphasize that it is necessary to design an $\textit{ad hoc}$ technique because the field is too singular to be captured with standard finite element methods.
BCCC16arxiv.pdf (3.66 Mo) Télécharger le fichier
Dissip.pdf (581.53 Ko) Télécharger le fichier
domain0.pdf (1.66 Ko) Télécharger le fichier
energy_compa_pis6_corners_om11.pdf (26.79 Ko) Télécharger le fichier
energy_compa_pis6_corners_om9_200pts.pdf (41.84 Ko) Télécharger le fichier
energy_compa_pis6_om11.pdf (19.85 Ko) Télécharger le fichier
energy_compa_pis6_om9_200pts.pdf (25.46 Ko) Télécharger le fichier
figs_mesh_1.pdf (90.49 Ko) Télécharger le fichier
figs_mesh_Euler.pdf (89.99 Ko) Télécharger le fichier
geometries.pdf (1.94 Ko) Télécharger le fichier
intro_euler_sym.pdf (2.2 Ko) Télécharger le fichier
spectre_DIC_5pis12_ND3.pdf (73.19 Ko) Télécharger le fichier
spectre_DIC_5pis12_ND4.pdf (73.91 Ko) Télécharger le fichier
spectre_HIC_5pis12_ND3.pdf (75.67 Ko) Télécharger le fichier
hal-01225309 , version 1 (06-11-2015)
hal-01225309 , version 2 (30-08-2016)
Anne-Sophie Bonnet-Ben Dhia, Camille Carvalho, Lucas Chesnel, Patrick Ciarlet. On the use of Perfectly Matched Layers at corners for scattering problems with sign-changing coefficients. Journal of Computational Physics, 2016, 322, pp.224-247. ⟨10.1016/j.jcp.2016.06.037⟩. ⟨hal-01225309v2⟩
656 Consultations
715 Téléchargements
