Geometric and Numerical Optimal Control with Application to Swimming at Low Reynolds Number and Magnetic Resonance Imaging. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2018
This series of notes have their origin into accelerated course in optimal control given to multidisciplinary Phd students in Mathematics, Physics or Control Engineering and the purpose is to present the seminal results of this theory in view of applications to concrete problems. For that we choose to make the presentation using two real life applications which are the core of current research projects on the academic side and motivated by industrial applications. The two applications concern the swimming at low Reynolds number and the contrast problem in Magnetic Resonance Imaging.
mono012018.pdf (3.48 Mo) Télécharger le fichier
hal-01226734 , version 1 (10-11-2015)
hal-01226734 , version 2 (11-03-2016)
hal-01226734 , version 3 (23-07-2017)
hal-01226734 , version 4 (28-11-2017)
hal-01226734 , version 5 (02-01-2018)
hal-01226734 , version 6 (27-04-2018)
hal-01226734 , version 7 (30-06-2018)
hal-01226734 , version 8 (07-08-2018)
  • HAL Id : hal-01226734 , version 5
Bernard Bonnard, Monique Chyba, Jérémy Rouot. Geometric and Numerical Optimal Control with Application to Swimming at Low Reynolds Number and Magnetic Resonance Imaging.. 2018. ⟨hal-01226734v5⟩
1370 Consultations
1078 Téléchargements
