PageRank in undirected random graphs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2015
PageRank has numerous applications in information retrieval, reputation systems, machine learning, and graph partitioning. In this paper, we study PageRank in undirected random graphs with expansion property. The Chung-Lu random graph represents an example of such graphs. We show that in the limit, as the size of the graph goes to infinity, PageRank can be represented by a mixture of the restart distribution and the vertex degree distribution.
RR-8983v2.pdf (961.86 Ko) Télécharger le fichier
hal-01227383 , version 1 (16-11-2015)
hal-01227383 , version 2 (25-11-2016)
Konstantin Avrachenkov, Arun Kadavankandy, Liudmila Ostroumova, Andrei Raigorodskii. PageRank in undirected random graphs. [Research Report] RR-8983, Inria Sophia Antipolis. 2015, pp.26. ⟨hal-01227383v2⟩
251 Consultations
1460 Téléchargements
