Well-posedness of the Prandtl equation in Sobolev space without monotonicity - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2015
We study the well-posedness theory for the Prandtl boundary layer equation on the half plane with initial data in Sobolev spaces. We consider a class of initial data which admit the non-degenerate critical points, so it is not monotonic. For this kind of initial data, we prove the local-in-time existence, uniqueness and stability of solutions for the nonlinear Prandtl equation in weighted Sobolev space. We use the energy method to prove the existence of solution by a parabolic regularizing approximation. The nonlinear cancellation properties of the Prandtl equations and non-degeneracy of the critical points are the main ingredients to establish a new energy estimate. Our result improves the classical local well-posedness results for the initial data that are monotone, analytic or Gevery class, and it will also help us to understand the ill-posedness and instability results for the Prandtl equation.
Prandtl-Nolinear-V1.pdf (535.68 Ko) Télécharger le fichier
hal-01228967 , version 1 (15-11-2015)
hal-01228967 , version 2 (31-12-2015)
hal-01228967 , version 3 (08-02-2016)
hal-01228967 , version 4 (18-02-2016)
hal-01228967 , version 5 (14-04-2016)
hal-01228967 , version 6 (07-05-2016)
Chao-Jiang Xu, Xu Zhang. Well-posedness of the Prandtl equation in Sobolev space without monotonicity. 2015. ⟨hal-01228967v1⟩
379 Consultations
219 Téléchargements
