Domain Decomposition for real time Simulation of needle insertion
Our goal is to develop robotized needle insertion for drug delivery in small animals. We control the robot with a real-time Finite Element simulation that provides accurate models of the deformable environment. To predict the deformations we need to solve a contact problem which is known to be time consuming. To reduce the computational time we use the domain decomposition method: the FE mesh is split in several domains in order to extract paral-lelism for GPU computing and to concentrate the computation time around the needle.
Poster.pdf (387.44 Ko)
Télécharger le fichier
talk_main.pdf (48.75 Ko)
