An Higher-Order Characterization of Probabilistic Polynomial Time - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Information and Computation Année : 2013
We present RSLR, an implicit higher-order characterization of the class PP of those problems which can be decided in probabilistic polynomial time with error probability smaller than one half. Analogously, a (less implicit) characterization of the class BPP can be obtained. RSLR is an extension of Hofmann's SLR with a probabilistic primitive, which enjoys basic properties such as subject reduction and confluence. Polynomial time soundness of RSLR is obtained by syntactical means, as opposed to the standard literature on SLR-derived systems, which use semantics in an essential way.
Informatique
ic2013.pdf (330.67 Ko) Télécharger le fichier
hal-01231752 , version 1 (17-12-2013)
hal-01231752 , version 2 (20-11-2015)
  • HAL Id : hal-01231752 , version 1
Ugo Dal Lago, Paolo Parisen Toldin. An Higher-Order Characterization of Probabilistic Polynomial Time. Information and Computation, 2013. ⟨hal-01231752v1⟩
117 Consultations
286 Téléchargements
