Observability conservation by output feedback and observability Gramian bounds - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Automatica Année : 2015
Though it is a trivial fact that the observability of a linear state space system is conserved by output feedback, it requires a rigorous proof to generalize this result to uniform complete observability, which is defined with the observability Gramian. The purpose of this paper is to present such a proof. Some issues in existing results are also discussed. The uniform complete observability of closed loop systems is useful for the analysis of some adaptive systems and of the Kalman filter.
observability.pdf (270.27 Ko) Télécharger le fichier
hal-01231786 , version 1 (20-11-2015)
Liangquan Zhang, Qinghua Zhang. Observability conservation by output feedback and observability Gramian bounds. Automatica, 2015, 60, pp.5. ⟨10.1016/j.automatica.2015.06.031⟩. ⟨hal-01231786⟩
203 Consultations
438 Téléchargements
