Experimental Evaluation of the Inverse Scattering Method for Electrical Cable Fault Diagnosis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Recently published theoretic and experimental results have shown the ability of inverse scattering-based methods to detect and to locate soft faults in electric cables, in particular, faults implying smooth spatial variations of cable characteristic parameters. The purpose of the present paper is to further experimentally evaluate the inverse scattering method for retrieving spatially distributed characteristic impedance from reflectometry measurements. With high quality coaxial cables connected in parallel, composite cables of piecewise constant characteristic impedance profiles are built in order to evaluate the accuracy of the inverse scattering method and its robustness in the presence of impedance discontinuities.
Safeprocess2015cable.pdf (315.2 Ko) Télécharger le fichier
hal-01232156 , version 1 (23-11-2015)
Florent Loete, Qinghua Zhang, Michel Sorine. Experimental Evaluation of the Inverse Scattering Method for Electrical Cable Fault Diagnosis. 9th IFAC Symposium on Fault Detection, Supervision and Safety of Technical Processes (SAFEPROCESS), Sep 2015, Paris, France. ⟨10.1016/j.ifacol.2015.09.619⟩. ⟨hal-01232156⟩
338 Consultations
250 Téléchargements
