On the quasi-hydrostatic quasi-geostrophic model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ESAIM: Mathematical Modelling and Numerical Analysis Année : 2017
This paper introduces a rigorous derivation of the quasi-hydrostatic quasi-geostrophic (QHQG) equations of large scale ocean as the Rossby number goes to zero. We follow classical techniques for the derivation of the quasi-geostrophic (QG) equations (as in [BB94]), but the primitive equations that we consider account for the nontraditional rotating terms, as in [LPR10]. We end up with a slightly different QG model with a tilted vertical direction, which has been illustrated in previous works using the primitive equations (see [PMHA97, She04, WB06, GZMvH08, SKR02]), and for which we prove local and global existence results.
main.pdf (299.97 Ko) Télécharger le fichier
hal-01232740 , version 1 (10-02-2011)
hal-01232740 , version 2 (11-02-2011)
hal-01232740 , version 3 (18-04-2011)
hal-01232740 , version 4 (25-03-2015)
hal-01232740 , version 5 (24-11-2015)
hal-01232740 , version 6 (01-06-2016)
hal-01232740 , version 7 (27-01-2017)
Carine Lucas, James C. Mcwilliams, Antoine Rousseau. On the quasi-hydrostatic quasi-geostrophic model. ESAIM: Mathematical Modelling and Numerical Analysis, 2017, 51 (2), pp.427-442. ⟨10.1051/m2an/2016041⟩. ⟨hal-01232740v4⟩
956 Consultations
818 Téléchargements
