Determination of nucleotides in Chinese human milk by high-performance liquid chromatography–tandem mass spectrometry - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Dairy Science & Technology Année : 2014
Gongnian Xiao
  • Fonction : Auteur
Hailong Xiao
  • Fonction : Auteur
Yinbang Zhu
  • Fonction : Auteur
Yuru You
  • Fonction : Auteur
The determination of nucleotide profile in human milk is an important issue for making nucleotide-fortified dairy products. Here, a method for the simultaneous quantitation of five monophosphate nucleotides (cytidine 5′-monophosphate (CMP), uridine 5′-monophosphate (UMP), adenosine 5′-monophosphate (AMP), inosine 5′-monophosphate (IMP), guanosine 5′-monophosphate (GMP)) in milk using high-performance liquid chromatography–tandem mass spectrometry (HPLC–MS/MS) was developed. The nucleotides were separated using a C18 column and gradient elution with water containing 0.1% (v/v) formic acid and acetonitrile. The method was validated with spike recoveries of 90.3–102.7% and 81.2–96.2%, and repeatability relative standard deviations of 2.5–4.3% and 2.6–4.6% for fresh bovine milk and milk powder, respectively. The method was applied for the assay of Chinese human milk samples collected from 59 nursing mothers with 2–4 months of lactation in Zhejiang, China. The mean (±SD) contents of CMP, UMP, AMP, IMP, and GMP are 3.1 ± 1.8, 2.2 ± 2.2, 0.23 ± 0.18, 0.018 ± 0.023, and 0.24 ± 0.19 mg.kg−1, respectively. The results of this work may serve as a guideline for the humanizing bovine milk-based infant formulas by supplementing the five monophosphate nucleotides for Chinese infants.
13594_2014_Article_182.pdf (867.98 Ko) Télécharger le fichier
Origine : Publication financée par une institution
hal-01234881 , version 1 (27-11-2015)
Gongnian Xiao, Hailong Xiao, Yinbang Zhu, Yuru You. Determination of nucleotides in Chinese human milk by high-performance liquid chromatography–tandem mass spectrometry. Dairy Science & Technology, 2014, 94 (6), pp.591-602. ⟨10.1007/s13594-014-0182-5⟩. ⟨hal-01234881⟩
31 Consultations
640 Téléchargements
