SPARQL Extensions with Preferences: a Survey - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The last decade has witnessed an increasing interest in expressing preferences inside database queries. Even though most of the work has been devoted to relational databases, many proposals have also been made in the Semantic Web area in order to query RDF databases in a flexible way. This paper presents a survey of these approaches, classifies them, and points out research perspectives.
SlamaPivertThion_SAC16.pdf (304.91 Ko) Télécharger le fichier
hal-01235190 , version 1 (23-11-2016)
Paternité
Olivier Pivert, Olfa Slama, Virginie Thion. SPARQL Extensions with Preferences: a Survey. ACM Symposium on Applied Computing, Apr 2016, Pisa, Italy, France. ⟨10.1145/2851613.2851690⟩. ⟨hal-01235190⟩
547 Consultations
403 Téléchargements
