Spatio-Temporal Linear Response of Spiking Neuronal Network Models
We study the impact of a weak time-dependent external stimulus on the collective statistics of spiking responses in neuronal networks. We extend the current knowledge, assessing the impact over firing rates and cross correlations, to any higher order spatio-temporal correlation [1]. Our approach is based on Gibbs distributions (in a general setting considering non stationary dynamics and infinite memory) [2] and linear response theory. The linear response is written in terms of a correlation matrix, computed with respect to the spiking dynamics without stimulus. We give an example of application in a conductance based integrate-and fire model.
