New interface
Conference papers
Regularization terms for motion estimation. Links with spatial correlations
Abstract : Motion estimation from image data has been widely studied in the literature. Due to the aperture problem, one equation with two unknowns, a Tikhonov regularization is usually applied, which constrains the estimated motion field. The paper demonstrates that the use of regularization functions is equivalent to the definition of correlations between pixels and the formulation of the corresponding correlation matrices is given. This equivalence allows to better understand the impact of the regularization with a display of the correlation values as images. Such equivalence is of major interest in the context of image assimilation as these methods are based on the minimization of errors that are correlated on the space-time domain. It also allows to characterize the role of the errors during the assimilation process.
Document type :
Conference papers
Complete list of metadata
Cited literature [13 references]  Display  Hide  Download
https://hal.inria.fr/hal-01235718
Contributor : Nathalie Gaudechoux Connect in order to contact the contributor
Submitted on : Monday, November 30, 2015 - 3:25:29 PM
Last modification on : Wednesday, June 8, 2022 - 12:50:03 PM
Long-term archiving on: : Tuesday, March 1, 2016 - 2:40:28 PM
File
Lepoittevin-Visapp-2016.pdf
Identifiers
Collections
Citation
Yann Lepoittevin, Isabelle Herlin. Regularization terms for motion estimation. Links with spatial correlations. VISAPP - International Conference on Computer Vision Theory and Applications, Feb 2016, Rome, Italy. pp.458-466, ⟨10.5220/0005712104560464⟩. ⟨hal-01235718⟩
Share
Metrics
Record views
143
Files downloads
297
