A New Representation of Systems with Frictional Unilateral Constraints and Its Baumgarte-Like Relaxation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Multibody System Dynamics Année : 2017
This paper proposes a new representation of multibody mechanical systems involving three-dimensional frictional unilateral constraints. The new representation is of the form of a differential algebraic inclusion (DAI) employing a normal cone with a non-Euclidean, singular norm metric. It can be seen as a generalization of a differential algebraic equation (DAE) using Lagrange multipliers, which has been used to represent mechanical systems with equality constraints. The paper also presents an approach to approximate the aforementioned DAI by another form of DAI, which can be equivalently converted into an ordinary differential equation (ODE). The approach can be seen as a generalization of the Baumgarte stabilization, which is originally for DAEs. The new DAI representation and its ODE approximation are illustrated with some simple examples.
15_1120_baum_relax.pdf (514.45 Ko) Télécharger le fichier
hal-01235861 , version 1 (01-02-2016)
Ryo Kikuuwe, Bernard Brogliato. A New Representation of Systems with Frictional Unilateral Constraints and Its Baumgarte-Like Relaxation. Multibody System Dynamics, 2017, 39 (3), pp.267-290. ⟨10.1007/s11044-015-9491-6⟩. ⟨hal-01235861⟩
1238 Consultations
215 Téléchargements
