Crustacea Decapoda: problem choices implemented from the literature. A worldwide bibliography from Andalusia
Crustacea Decapoda: selección de problemas planteados en la literatura. Una bibliografía mundial desde Andalucía
Crustacea Decapoda: choix de problèmes au coeur de la littérature. Une bibliographie mondiale d'origine andalouse
A database has been constructed compiling virtually all the worldwide known larval developments of the Crustacea Decapoda. 4031 entries list this morphologic analysis. The criteria of relevance, comprehensiveness, and reliability applicable to this bibliography permit an objective evaluation of the relative importance of scientific research problems in the area. The data structure of the database is spread over the scientific literature to see what falls into the grid. All the data from a specimen, a gender, a family, and an infraorder have been introduced. The literature coverage is described with a special field. The practical foundation for a problem choice activity is focused on the field where the controlled stages of the evolution of the larvae are recorded. Zoeal stages names result from the application of knowledge procedures deriving in morphologic attributes. Until the Last Stage is attained the distributive lattice between the considered attributes defines a logically inconsistent situation. This must be discerned in terms of fuzzification. At least two such criteria are present in the initially defined stage with no idea of the last stage, and the changes of names along time. In terms of the material properties of the database it is said that the condition of reliability may be expressed as the "density" of the distribution of the attributes. A theory of the specimen described, in the sense of finally giving it a name, must be a conjunction of data from the Lab (L) and from the plankton (P): (L+P). And this will be the criteria of quality when solving problems. The impasses detected when trying to attain this ideal would identify possible research questions. An integrated set with the names of the most important journals and authors, and results on the more informative years in the discipline are also included.
Se ha elaborado una base de datos compilando virtualmente todos los desarrollos larvarios conocidos de Crustacea Decapoda. Éste análisis morfológico enumera 4031 entradas. Son aplicables a ésta bibliografía criterios de relevancia, exhaustividad y fiabilidad, que permiten una evaluación objetiva de la importancia relativa de los problemas de investigación científica dentro del área. La estructura de la base de datos se extiende a toda la literatura científica, para examinar lo que responde a su retículo. Donde están introducidos todos los datos que corresponden a un espécimen, a un género, a un infraorden. La cobertura de la literatura se describe con un campo especial. La base práctica para la actividad de elección de un problema está centrada en los estadios de la evolución larvaria que se está controlando, y en las modificaciones de los nombres a lo largo del tiempo. De la aplicación de los procedimientos de conocimiento que derivan en atributos morfológicos resultan los nombres de los estadios zoea. Hasta que se alcanza el último estadio el retículo distributivo entre los atributos que se consideran define una situación logicamente inconsistente.
Esto debe diseñarse en términos de fuzzificación. Al menos dos de estos criterios están definidos en el estadio inicialmente definido sin que se disponga de una idea de cual va a ser el estadio final, ni de cuáles van a ser los cambios de los nombres a lo largo del tiempo. En términos de las propiedades materiales de la base de datos, cabe decir que la condición de fiabilidad se puede expresar como la "densidad" de la distribución de los atributos. Una teoría del especimen descrito, en el sentido de finalmente darle un nombre, debe resultar de la conjunción de los datos del Laboratorio (L) y del plancton (P): (L+P). Y este será el criterio de calidad al resolver problemas. Los obstáculos detectados cuando se intenta alcanzar este ideal, podrían identificar posibles preguntas de investigación. Se incluye también un conjunto integrado con los nombres de las revistas, los autores y los resultados más importantes en los años de carácter más informativo dentro de la disciplina.
Une base de données a été créée pour compiler presque toute l'activité mondiale sur le développement larvaire de Crustacea Decapoda. 4031 entrées sont énumérées dans cette analyse morphologique. Les critères d'utilité, exhaustivité et fiabilité applicable à cette bibliographie autorisent à réaliser une évaluation objective de l'importance relative des problèmes de la recherche scientifique dans le domaine. La structure de cette base de données est étalée sur la littérature scientifique pour examiner ce qui tombe sur le cadre de grille. Toutes les données pour le spécimen, le genre, la famille, et l'infraordre ont été mises en place. Le littérature est couverte par une description avec un champ spécial. L'activité de choix d'un problème est fondée en pratique en fait axée sur le champ là où les étapes contrôlées de l'évolution des larves s'y régistrent. Les noms des stades zoé résultent de l'application des procédures de connaissances conduisant à des attributs morphologiques. Jusqu'à ce que le dernier stade est atteint le treilli distributif entre les attributs pris en considération définit une situation d'inconsistance logique. Cela doit être discerné en termes de fuzzification. Au moins deux critères sont présents dans le stade initialement défini sans savoir quel sera le dernier stade, ainsi que les modifications des noms au cours du temps. En termes de propriétés matérielles, c'est notamment le cas de la condition de fiabilité de la base de données, elles peuvent être exprimées comme la "densité" de la distribution des attributs. Une théorie du spécimen décrit, finalement dans le sens de lui donner un nom, doit mettre en conjonction les données du Lab (L) et ceux du plancton (P): (L+P). Et cela sera du ressort des critères de qualité pour régler les problèmes. Les impasses détectées lorsqu'on essaie d'obtenir cet idéal comporterait l'identification possible des exemples d'objets de recherche envisageables dans ce contexte. Figure également un ensemble integré des
noms des journaux et des auteurs, et des résultats plus importants d'après les années plus informatives.
