Observer Design for Unilaterally Constrained Lagrangian Systems: A Passivity-Based Approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Automatic Control Année : 2016
This paper addresses the problem of state estimation in nonlinear Lagrangian dynamical systems with frictionless unilateral constraints using the position measurement as output. The discontinuous velocity variable in such systems is modeled as a function of bounded variation (so that Zeno phenomenon is not ruled out). Since the derivative of such functions is represented with the Lebesgue-Stieltjes measure, the framework of measure differential inclusions (MDIs) is used to describe the dynamics. A class of estimators is proposed, which also uses the framework of MDIs, and is shown to generate asymptotically converging state estimates. The existence and uniqueness of solutions for the proposed estimators is rigorously proven. The global stability of error dynamics is analyzed using the generalized Lyapunov methods for functions of bounded variation. As particular cases of our estimators, we provide an explicit construction of a full-order observer, and a reduced-observer.
ATBBCPO.pdf (384.78 Ko) Télécharger le fichier
hal-01113344 , version 1 (05-02-2015)
hal-01113344 , version 2 (18-09-2015)
hal-01113344 , version 3 (01-11-2017)
Aneel Tanwani, Bernard Brogliato, Christophe Prieur. Observer Design for Unilaterally Constrained Lagrangian Systems: A Passivity-Based Approach. IEEE Transactions on Automatic Control, 2016, 61 (9), pp.2386-2401. ⟨10.1109/TAC.2015.2492098⟩. ⟨hal-01113344v3⟩
943 Consultations
424 Téléchargements
