Futex based locks for C11's generic atomics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2015
Verrous basés sur futex pour les opérations atomiques génériques de C11
We present a new algorithm and implementation of a lock primitive that is based on Linux' native lock interface, the futex system call. It allows us to assemble compiler support for atomic data structures that can not be handled through specific hardware instructions. Such a tool is needed for C11's atomics interface because here an _Atomic qualification can be attached to almost any data type. Our lock data structure for that purpose meets very specific criteria concerning its field of operation and its performance. By that we are able to outperform gcc's libatomic library by around 60%.
RR-8818.pdf (694.84 Ko) Télécharger le fichier
hal-01236734 , version 1 (02-12-2015)
  • HAL Id : hal-01236734 , version 1
Jens Gustedt. Futex based locks for C11's generic atomics. [Research Report] RR-8818, INRIA Nancy. 2015. ⟨hal-01236734⟩
676 Consultations
1269 Téléchargements
