Stochastic Fluid Dynamic Model and Dimensional Reduction - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper uses a new decomposition of the fluid velocity in terms of a large-scale continuous component with respect to time and a small-scale non continuous random component. Within this general framework, a stochas-tic representation of the Reynolds transport theorem and Navier-Stokes equations can be derived, based on physical conservation laws. This physically relevant stochas-tic model is applied in the context of the POD-Galerkin method. In both the stochastic Navier-Stokes equation and its reduced model, a possibly time-dependent, inhomoge-neous and anisotropic diffusive subgrid tensor appears naturally and generalizes classical subgrid models. We proposed two ways of estimating its parametrization in the context of POD-Galerkin. This method has shown to be able to successfully reconstruct energetic Chronos for a wake flow at Reynolds 3900, whereas standard POD-Galerkin diverged systematically.
6B-1.pdf (338.8 Ko) Télécharger le fichier
hal-01238301 , version 1 (04-12-2015)
  • HAL Id : hal-01238301 , version 1
Valentin Resseguier, Etienne Mémin, Bertrand Chapron. Stochastic Fluid Dynamic Model and Dimensional Reduction. International Symposium on Turbulence and Shear Flow Phenomena (TSFP-9), Jun 2015, Melbourne, Australia. ⟨hal-01238301⟩
228 Consultations
245 Téléchargements
