Partial observer normal form for nonlinear system - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Automatica Année : 2016
In this paper, we investigate the estimation problem for a class of partially observable nonlinear systems. For the proposed Partial Observer Normal Form (PONF), necessary and sufficient conditions are deduced to guarantee the existence of a change of coordinates which can transform the studied system into the proposed PONF. Examples are provided to illustrate the effectiveness of the proposed results.
Automatique
V_final.pdf (193.85 Ko) Télécharger le fichier
hal-01239583 , version 1 (08-12-2015)
Ramdane Tami, Gang Zheng, Driss Boutat, Didier Aubry, Haoping Wang. Partial observer normal form for nonlinear system. Automatica, 2016, 64, pp.54-62. ⟨10.1016/j.automatica.2015.10.041⟩. ⟨hal-01239583⟩
237 Consultations
431 Téléchargements
