Autonomic Management using Self-Stabilization for Hierarchical and Distributed Middleware - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Dynamic nature of distributed architecture is a major challenge to avail the benefits of distributed computing. An effective solution to deal with this dynamic nature is to implement a self-adaptive mechanism to sustain the distributed architecture. Self-adaptive systems can autonomously modify their behavior at run-time in response to changes in their environment. This capability may be included in the software systems at design time or later by external mechanisms. Our paper describes the self- adaptive algorithm that we developed for an existing middleware. Once the middleware is deployed, it can detect a set of events which indicate an unstable deployment state. When an event is detected, some instructions are executed to handle the event. We have designed a simulator to have a deeper insights of our proposed self-adaptive algorithm. Results of our simulated experiments validate the safe convergence of the algorithm.
dasc2015 (1).pdf (394.79 Ko) Télécharger le fichier
hal-01239792 , version 1 (08-12-2015)
Paternité - Pas d'utilisation commerciale - Pas de modification
  • HAL Id : hal-01239792 , version 1
Eddy Caron, Maurice-Djibril Faye, Ousmane Thiare. Autonomic Management using Self-Stabilization for Hierarchical and Distributed Middleware. The 2015 International Symposium on Advances in Autonomic and Secure Computing and Communications (ASCC-2015). In conjunction with DASC-15., Oct 2015, Liverpool, United Kingdom. ⟨hal-01239792⟩
417 Consultations
165 Téléchargements
